2004 Jeep Liberty, Remote Start
tedt21
Posted: October 14, 2024 at 5:51 AM / IP Logged Link to Post Post Reply Quote tedt21
I installed a Idatastart CMHCXAO with RF3452AE RF remotes on my daughters 2004 Jeep Liberty. The Jeep has grey headed keys and is equipped with the factory alarm. The install went well and the RF remotes work to remote start the vehicle, and the tailgate glass open function from the remote works as well. The only functions not working is the lock and unlock buttons on the RF remotes do not lock or unlock the vehicle. The cars parking lights flash, but the locks do not react. The factory remotes still work to lock and unlock the vehicle. Any help with this would be greatly appreciated.
tt
lee.lopez
Member - Posts: 46
Posted: October 14, 2024 at 6:47 AM / IP Logged Link to Post Post Reply Quote lee.lopez
I see the install manual shows 2 possible connections for the door lock mux wire. If you haven't tried yet, I'd try swapping mux wires.
If you have it connected to the light green/orange wire in the BCM connector 1 pin 9, try swapping to the pink/purple wire in the BCM connector 2 pin 10.
tedt21
Posted: October 14, 2024 at 10:18 AM / IP Logged Link to Post Post Reply Quote tedt21
I did notice that there was 2 options, but the option with the pink/purple wire was for vehicle without a factory alarm, which this car has.
tt
tedt21
Posted: October 14, 2024 at 12:54 PM / IP Logged Link to Post Post Reply Quote tedt21
Is there a possibility that either the switch located behind the key cylinder in the driver's door or the wiring between the stitch and the BCM could be the problem?
tt
lee.lopez
Member - Posts: 46
Posted: October 14, 2024 at 3:42 PM / IP Logged Link to Post Post Reply Quote lee.lopez
You could test with a meter to be sure.
Tuesday, October 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
