CT-5000 Prostart
highvoltage
Posted: November 23, 2003 at 9:26 PM / IP Logged
Before I start Wiring, does any one have total schematics of how this whole system is wired?
Thanks!!!
ck auto
Copper - Posts: 257
Posted: November 23, 2003 at 10:22 PM / IP Logged
hi let me know what you need are far as schematics and ill see what i can do .
thks
kirk
highvoltage
Posted: November 24, 2003 at 9:57 AM / IP Logged
What I need is an overall schematic of what parts are involved. Example, does the relay provided in kit used and if so how?
Does the (+)30 A 5th relay output need to be wired' ifso what to?
Does the (-) rearm output connect to door pin for interior lights?
Where does the (-) ground out when running wire connect to?
I am putting this into a 1998 Dodge Ram with no power door locks or windows, does this cause a problem with this unit?
Thanks!!!
HamiltonAudio
Silver - Posts: 278
Posted: November 29, 2003 at 1:06 PM / IP Logged
it sounds to me like you should do a little more reading before you tackle the install.  The 5th relay is only if you need to power a second ignition or starter wire (jumper on back of unit to set).  This depends on the vehicle.  The re-arm wire will only be used on a vehicle that has factory security that you'd like to (and are able to) rearm.  The ground out when running wire is only useful for triggering relays and data modules to bypass security, clutches, etc.  Likely not used.
b
