Shock Sensor 101
Jerry Siemens
Member - Posts: 17
Posted: August 12, 2002 at 10:29 AM / IP Logged
My CrimeGuard alarm came with a two stage shock sensor that was worthless. Even at highest sensitivity, I could not make the system even chirp. If I tapped it with my finger, it would work fine. Salepeople said this is common.
On my son's car, if I even try to remove a wheelcover, the unit chirps a warning.
My question is "Who makes a good one?" It should chirp if I rock the car slightly, and alarm if I get violent (which I have been getting more and more, lately!!)
Thanks for any advice.
Jerry Siemens
Novice Installs
Moderator - Posts: 12,488
Posted: August 12, 2002 at 2:19 PM / IP Logged
It depends on where you mounted the shock sensor . If you mounted it on a wire loom your not going to get as good a response from the sensor as opposed to mounting it to a flat solid piece of plastic or metal.
Jerry Siemens
Member - Posts: 17
Posted: August 13, 2002 at 6:25 AM / IP Logged
Jeff,
Hello, again!  Yes, it was mounted on a rigid piece of steel, under the dash.  ( and that ain't easy to find on a Corolla!).  I honestly do not believe this thing would have reacted unitl someone ran into my car, with another car, that is.  I assume the sensor I was using was mfg by Omega.
Thanks for your reply.
Jerry Siemens
hot_shot_guy123
Copper - Posts: 114
Posted: August 13, 2002 at 8:40 AM / IP Logged
What position is your shock sensor in?  For my UNGO alarm the most sensitive position is vertical attached to a solid piece of plastic or metal.  I had it horozontal before and like your thinking, I thought that only a semi hitting it would set it off.  Since I mounted it vertically it's been much much better.
"Light travels faster then sound, that's why some people seem bright until you hear them speak."
hot_shot_guy123
alitaki
Member - Posts: 8
Posted: August 13, 2002 at 1:03 PM / IP Logged
The steering column or part of the underdash that connects to it is a good area mount a shock sensor.
Big Dog
Gold - Posts: 1,265
Posted: August 13, 2002 at 2:53 PM / IP Logged
Hey folks,
I'm surprised this one got by you guys!  He said his car is a Corolla, but he never mentionned what his son's car is! Maybe it's a Civic and so it's normal that it would be more sensitive.   Also, a shock sensor is just that. . .an impact detector. . . so rocking the car will not set it off.  Instead it has to be tested by slapping the windows with the palm of your hand.   My experience with Corollas is that the shock has to be mounted DEAD CENTER of the vehicle in front of the console to respond the same way on both sides of the car because of the way the car is built.  Not all impact sensors work on solid surfaces,  for example DEI's impact is tye-wrapped to an existing underdash harness.  I think though that Jerry summed it up well when he said, "My CrimeGuard alarm came with a two stage shock sensor that was worthless." Shock Sensor 101 -- posted image.
Prepare your future. It wasn't the lack of stones that killed the stone age.
gferguso
Member - Posts: 12
Posted: August 13, 2002 at 4:01 PM / IP Logged
I just installed a crime guard in my son's car and i'm having the same problem with the shock sensor. Is there a shock sensor i can buy to replace the one that is worthless?
Gferg
Jerry Siemens
Member - Posts: 17
Posted: August 14, 2002 at 8:52 AM / IP Logged
I think Big Dog wins this one!  He hit the nail on the head when he said the shock sensor will not detect motion.  You see, I an a newby and semantics got in my way!  What I really want, and need, is a good quality m-o-t-i-o-n detectior.  The reason being I want to deter anyone from jacking-up and removing wheels, in particular.
I have E-mailed a few sites I found on the web, but have not gotten any good responses, yet.  I guess they already have more business than they need!
So, that being said; as "gferguso" asked, is there a sensor (motion) that someone has good luck with?
Thanks to all who responded.
Jerry
hot_shot_guy123
Copper - Posts: 114
Posted: August 14, 2002 at 9:05 AM / IP Logged
If your worried about someone jacking up your car and stealing your wheels then what your looking for is a "Tilt Sensor"  Different from a shock and motion sensor all together.
hot_shot_guy123
Big Dog
Gold - Posts: 1,265
Posted: August 14, 2002 at 9:52 AM / IP Logged
Hey   Jerry Siemens,
What you're looking for is a motion/tilt sensor.  Clifford has one that's easy to install and is fully digital meaning that it even works on inclines.  It has two incline sensitivities, 0.5° and 1.0°.  Ask for part number 905085.  Shock Sensor 101 -- posted image.
Monday, September 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
