2001 Tahoe Onstar Bypass?
cb229
Member - Posts: 6
Posted: May 15, 2004 at 12:58 PM / IP Logged
I'm trying to install a new head unit in my 2001 tahoe.  After installation there is no sound. After reading a few threads here I see it is because of the Onstar system and it needs some kind of adapter. I never use onstar and it is not even subscribed to their service.  Is there a way to just completely bypass this?  Does anyone have a diagram for the other small harness that goes into the back of the stock unit?
sexyvic1
Copper - Posts: 144
Posted: May 16, 2004 at 12:37 AM / IP Logged
whats up buddy? i am pretty sure that you will need to wire harness's from metra
one is the 70-1858
and the other is the 70-2006 ( i believe this is the one for the onstar )
good luck
sexyvic1
Copper - Posts: 144
Posted: May 16, 2004 at 12:38 AM / IP Logged
whats up buddy? i am pretty sure that you will need two wire harness's from metra
one is the 70-1858
good luck
cb229
Member - Posts: 6
Posted: May 16, 2004 at 4:27 AM / IP Logged
I do not want the Onstar hooked up,  I do not use it.  There is got to be a way to do this without buying a harness. I spliced into the pink wire on the small harness and hooked it to power like I read from a post here.  The sound came on and everything worked but there was a spark popping noise coming from the factory amp so I know that is not right.  It is close though.  All I need is a diagram for the seperate small harness!
jwLLL
Posted: May 23, 2004 at 1:13 AM / IP Logged
You are going to have to bypass the factory amp with 4 speaker wires. That's it. No harness. Under glove box. Not to each speaker.
Wednesday, September 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
