1st time install question
xoutlawz00x
Member - Posts: 28
Posted: May 20, 2004 at 11:05 PM / IP Logged
Do i need to solder or use any thing specail like diodes to install an alarm or can i  just make the connection and tape it real good to make sure it doesn't move
Moderator - Posts: 12,488
Posted: May 20, 2004 at 11:25 PM / IP Logged
Always use solder for your connections and depending on the vehicle, you may need relays, diodes and resistors. If this is for the 1997 Civic, then there is nothing special that is needed for the installation of the alarm system.
* Also, I didn't find any pics on my computer in regards to the actuator pictures for the Civic, sorry 1st time install question -- posted image.
profuse007
Gold - Posts: 2,015
Posted: May 20, 2004 at 11:26 PM / IP Logged
what type of car?
the way that i make the connection is to slice the objective wire and split the strands in half, then stick the wire to it, then wrap the wire around it, and then tape it.
i have some pic of the actuator for 92-95 civic somewhere, i have to find it
Houston,TX
xoutlawz00x
Member - Posts: 28
Posted: May 21, 2004 at 9:15 AM / IP Logged
thanks
xoutlawz00x
Member - Posts: 28
Posted: May 22, 2004 at 9:46 PM / IP Logged
yea its for a 1997 civic hatchabck no factory alram
