Power Anteena wires Mit. Eclipse 2001
Jtzdragon77
Posted: July 26, 2004 at 1:32 PM / IP Logged
I have a 2001 Mitsubishi Eclipse Spyder and trying to find out if anyone has the wire diagram for the power antenna. Basically I'm trying to find  a hot switchable sourch for an amp in the back. Another question is when the car is on and the power antenna is up is the hot lead on constantly or does it shut off whrn the antenna fully extends and then when you turn the car off or the stereo for that matter is power applied to another wire to bring it back down. I'm well aware I could figure all of this out with a multi-meter but I.m at work right now without access to one. Thanks for any help that is given.
Jtzdragon77
Posted: July 26, 2004 at 4:48 PM / IP Logged
Never mind.  I used another spot as a switchable.. thanks though
