Sunroof Wiring, 2002 Sequoia
bretbowman
Copper - Posts: 156
Posted: March 03, 2005 at 9:33 PM / IP Logged
I still can't seem to find the wiring diagram for the sunroof MOTOR wires....
2002 Toyota Sequoia Limited 2WD (Clifford G5 Avantguard 5 w/ 2 SmartWindows modules) - IT Engineer - NRA Life Member - LDS Return Missionary - Married for time AND ETERNITY - Eternally sealed family
bretbowman
Copper - Posts: 156
Posted: March 07, 2005 at 2:50 AM / IP Logged
I think that I may just order an extra 530T for the sunroof and rear window and just wire the sunroof so that it only closes when the alarm arms.  I do not need remote opening of the sunroof from the remote control.
Is there any real good reason to wire remote sunroof that I'm not thinking of?
edrock200
Member - Posts: 23
Posted: March 07, 2005 at 7:43 AM / IP Logged
Couldn't you use your roll-up module to wire into the key cylinder wire as a previous poster stated? Instead of sending + or - to the motor it could send a + or - to the key cylinder and roll up all your windows and sunroof at once...or am I missing something?
Bnluis
Silver - Posts: 578
Posted: March 07, 2005 at 3:22 PM / IP Logged
http://www.carsound.com/UBB/ultimatebb.php?ubb=get_topic;f=3;t=001866#000000
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
bretbowman
Copper - Posts: 156
Posted: March 14, 2005 at 6:12 AM / IP Logged
At least answer this for me.... someone?
Why does DEI NOT recommend automating sunroof open/close?
bretbowman
Copper - Posts: 156
Posted: March 19, 2005 at 3:09 PM / IP Logged
I think I got the sunroof figured out (at least to close when armed), but it's wiring negative (timed) output at the switch.  With the link above, I don't see how (or when) the signal output gets turned off.  If my sunroof and/or windows do not have a limiting swtich, then my sunroof motor might burn out using this configuration.  How is this avoided?
