Compustar remote start in 01 civic
j0hns0n
Member - Posts: 6
Posted: January 18, 2006 at 9:20 PM / IP Logged
I have recently installed a Compustar 2WSS-AS alarm in my 01 civic. I did not connect the 2nd accessory because i did not know where to connect it. Could that be why the car will not crank when i try to remote start?
mo12v
Posted: January 18, 2006 at 9:44 PM / IP Logged
What did you use for a ByPASS?
Why didn' t you finish the Install prior to Remote Starting?
Constant 12 voltsWHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK / YELLOWIGNITION SWITCH HARNESS
StarterBLACK/ WHITEBACK OF DRIVER FUSE BOX *
* Installing A Starter Kill Relay At The Ignition Switch Harness Before The Starter Wire Enters The Driver Side Fuse Block May Cause A "Check Engine" Light To Come On. Starter Wire Should Be Accessed After Fuse Block.
Ignition #2BLACK/ REDIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryWHITE/ REDIGNITION SWITCH HARNESS
Immobilizer Bypass
MO
05gt
Silver - Posts: 628
Posted: January 18, 2006 at 9:45 PM / IP Logged
You need that wire for the 2nd ignition wire in the vehicle
have you programmed the remote, have you programmed tach, have you gone over everything to make sure it is all hooked up properly
that vehicle requires a bypass for the factory immobilizer, part number is 556H (no key required) or the 556U (extra key required) all parts are from DEI
j0hns0n
Member - Posts: 6
Posted: January 18, 2006 at 10:31 PM / IP Logged
I have yet to install the bypass, but shouldn't the remote start work with the key in the ignition? (just to check if remote start works)
j0hns0n
Member - Posts: 6
Posted: January 18, 2006 at 10:46 PM / IP Logged
We did not have time to finish the install so we just got the alarm working and left the bypass for another day. Im guessing its the status wire not being hooked up yet.
