07 Chevrolet Tahoe Alarm/Remote Start/Stereo Wiring
Strizzy23
Member - Posts: 42
Posted: July 22, 2006 at 2:08 PM / IP Logged
i need a wiring for a 07 chevy tahoe with the bose audio i need to hook up a loc until the harness comes out
1stclasso
Member - Posts: 36
Posted: July 22, 2006 at 9:39 PM / IP Logged
dont have the audio, u wil have to find the factory amp and test !
this is the best i could provide!
Constant 12 voltsWIRE GAGE TO SMALLCONNECT AT UNDERDASH FUSE BLOCK.
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterNO STARTER WIRESEE TECH ***
Dome LightGRAY/BLACK (+)AT BCM * C5 BROWN PIN E SEE TECH**
Trunk Pin SwitchPINK/BLACK (-)AT BCM * C6 PINK PIN 15 SEE TECH**
Parking LampGREY/BLACK (-)AT MAIN SWITCH
Power LockDR PU, PASS GR/BLKIN EACH DOOR DUE TO #203
Power UnlockDR TAN,PASS TANMULTIPLEXING **
* BCM Located Below Steering Column Alt Dr Door Pin Is BROWN And Pass Door Pin Is BLACK/ WHITE These Wires Are Located In The Doors Polarity Is Hard To Determin From Shop Manual.Drivers Rear L BLUE (-) Pass L GREEN/ BLACK (-) At BCM Conn C6 Pins 14 and 15. ** Rear Doors And End Gate Can Be Cotroled From The BCM SEE TECH ** #203- See Reversal Rest at Ground Door Lock Diagram.
Tach SignalWHITEAT PCM * #241
Ignition #2WHITEIGNITION SWITCH HARNESS
Ignition #3ORANGEIGNITION SWITCH HARNESS
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyWHITE (-)PCM CONN C3 PIN #13 *
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightLIGHT GREEN (+)EITHER TAIL LT ASSY OR TRAILER CONN**
Rear Window DefrostN/A
*PCM Located On The Drivers Side Of The Motor. Tach Wire Is In The BLUE Conn (C1) Closest To The Firewall,Pin #49. Also Found Back Of Cluster in 24 pin GREY Conn Pin # A12 ** Also Found At BCM In 6 Pin Black Connector #241- GM Passlock 2004 Interface Diagram ( Wire Colors Are WHITE And PINK ) Use WHITE (Pin 5) & PINK (Pin 6) Wires At Ignition Switch Cut WHITE wire.
Strizzy23
Member - Posts: 42
Posted: July 22, 2006 at 9:57 PM / IP Logged
thanks for the reply
josh1979
Silver - Posts: 320
Posted: July 22, 2006 at 10:17 PM / IP Logged
Radio 12v RED / white  +  radio harness
Radio Ground black  -  radio harness
Radio Ignition (GMLAN Serial Data)
Radio Illumination yellow (dimmer)  +  radio harness
Factory Amp Turn-on same as power antenna wire
Power Antenna white  +  radio harness
LF Speaker +/- tan - gray  +,- radio harness or amplifier
Notes: If equipped, the amplifier is under the rear of the center console.
At the amplifier, the left subwoofer wires are dk. blue/white (+) - lt. GREEN/ black (-). The right subwoofer wires are dk. green (+) - lt. blue/black (-).
RF Speaker +/- lt. green - dk. green  +,- radio harness or amplifier
LR Speaker +/- brown - yellow  +,- radio harness or amplifier
RR Speaker +/- dk. blue - lt. blue  +,- radio harness or amplifier
07 Chevrolet Tahoe Alarm/Remote Start/Stereo Wiring - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PASS-Key III+
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Smart Starter Kill Relays:Relay Type:
Starter Relay
Engine compartment fusebox, Driver side
Part #: 6404A
12volts RED / white (2A)  +  ignition harness
Notes: For high current 12V, use RED / black (60A) and RED / black (60A) at the fuse box, black 40 pin plug, pins F1 and E3, or go to the battery.
Ignition pink  +  ign harn or BCM, lt. grn plg, pin 14
Notes: The BCM (Body Control Module) is to the left of the steering column.
Parking Lights+ brown (L), brown (R)  +  underhood fuse box, blk 30 pin plug
Parking Lights- lt. blue  -  switch or BCM, natural plug, pin 8
Headlight white  -  switch or BCM, natural plug, pin 12
Trunk/Hatch Release pink (glass), gray (gate)  -  BCM, pink plug, pins 24 and 13
Notes: Meter these wires while opening the liftglass or liftgate from the handle on the rear liftgate.
On vehicles with the power liftgate, use dk. GREEN / WHITE (-) at the switch in the overhead console.
Power Sliding Door N/A
Speed Sense yellow/black    ECM, black 73 pin plug, pin 57
Notes: The ECM (Engine Control Module) is in the front driver side of the engine compartment.
Wipers gray  +  BCM, brown plug, pin 20
LF Window up/dn dk. blue - brown  A  DDM, black 6 pin plug, pins 3 and 1
Notes: The DDM (Driver Door Module) is in the driver door.
RF Window up/dn dk. blue - brown  A  PDM, black 6 pin plug, pins 3 and 1
Notes: The PDM (Passenger Door Module) is in the passenger door.
LR Window up/dn dk. blue - brown  A  LR window switch in door, pins E, H
RR Window up/dn dk. blue - brown  A  RR window switch in door, pins E, H
Sun Roof open/close motor part of module
Sun Roof Limit/close N/A
Memory Seat 1 orange  +  switch or DDM, blk 26 pin plg, pin 5
Notes: Memory seat 1 is positive trigger thru a 2260 ohm resistor. Memory seat 2 is positive trigger thru a 4260 ohm resistor.
Memory Seat 2 same as memory seat 1 wire  +
Memory Seat 3 N/A  +
bring back the rotary phone so i dont have to press 1 to proceed in english
Strizzy23
Member - Posts: 42
Posted: July 22, 2006 at 10:40 PM / IP Logged
Thanks josh1979 i have no ideal where you find that but thanks
forklift
Member - Posts: 14
Posted: July 28, 2006 at 1:16 AM / IP Logged
I just did one today with Bose for a Parrot 3100 Bluetooth
speakers were normal old chevy colors under the huge pocket in the center console that just pops up and slides out at the front. They were the lt. blue/ dark blue, yellow/brown, tan/grey, lt GREEN/ dark green at a huge harness connector that goes towards the amp. You can also find a pink thats a 12v acc(comes on/off with the radio on/off not ignition, but its not an amp turn on), you have a black ground and 3 constants that are all RED / white. Funny part was that the tweeters are also caught on the front speaker wires and arent seperate, but passsively cross overed. The stock sub(s) are on the right side in a 4 pin connector. I dont know if its 2 subs or a dual voice coil, but they are RED / green and WHITE/ red / WHITE/ green. We did it right and used relays to kill the subs when the Parrot kicked in so have fun
hoping I pass the 1st class for the first time on 5-18-6, wish me luck!
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
