12volts WHITE/ red (30A), white (5A) + ignition harness
Starter BLACK/ white + ignition harness
Second Starter BLACK / YELLOW + ignition harness
Ignition BLACK/ red + ignition harness
Second Ignition BLACK / YELLOW + ignition harness
Third Ignition N/A
Accessory blue/red + ignition harness
Second Accessory N/A
Keysense blue - ign harn or BECU, top plug, pin 19
Notes: Using the status output to trigger this wire during remote start will disarm the alarm without unlocking the doors.
The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge.
Power Lock blue / YELLOW - DKP or bottom of fusebox, 20 pin plg
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock blue (double pulse) - DKP or BECU, top plug, pin 22
Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is blue/white (-) in the BECU, top plug, pin 21.
Lock Motor blue/red 5wi DKP or bottom of fusebox, 13 pin plg
Unlock Motor blue/black 5wi DKP or BECU, bottom plug, pin 11
Notes: The Body ECU is attached to the back of the fuse box under the driver side dash. The plugs for the BECU are on the left side edge.
Parking Lights+ green + DKP or bottom of fusebox, 20 pin plg
Parking Lights- red - switch or BECU, top plug, pin 8
Hazards lt. GREEN/ black - switch or BECU, middle plug, pin 10
Turn Signal(L) GREEN / WHITE + turn signal flasher relay in DKP
Turn Signal(R) GREEN/ YELLOW + turn signal flasher relay in DKP
Reverse Light RED / black + DKP or bottom of fusebox, 20 pin plg
Door Trigger see notes - see notes
Notes: The LF door is RED / green in the BECU, bottom plug, pin 1. The RF door is RED / green in the BECU, top plug, pin 11. The rear doors are RED / white in the bottom of the fuse box, 20 pin plug, pin 7. Use all three wires and diode isolate each.
Dome Supervision GREEN/ red - ignition key cylinder light
Trunk/Hatch Pin green - DKP or BECU, bottom plug, pin 6
Hood Pin black - theft deterrent ECU behind glovebox
Trunk/Hatch Release WHITE/ blue 5wi DKP or BECU, bottom plug, pin 12
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer BLACK/ orange ac ECM behind glovebox
Notes: On the 4 cylinder models, it is in the 2nd plug from the top, pin 1. On the 6 cylinder models, it is in the top plug, pin 5.
Can also go to any ignition coil or fuel injector and use the wire that is NOT BLACK/ red, WHITE/ red, or WHITE/ black.
Wait to start N/A
Brake Wire GREEN / WHITE + sw or bottom of fusebox, 20 pin plug
Parking Brake RED / white - parking brake switch
Horn Trigger GREEN/ black - sw or bottom of fusebox, 24 pin plug
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
