2002 Toyota Highlander
Mr_Fusion
Copper - Posts: 113
Posted: January 28, 2003 at 10:29 PM / IP Logged
Hello, I am looking for a remote start with alarm wiring diagram for a 2002 Toyota Highlander.  I've seen various posts that I must go into either the driver or passenger doors to tap into the power locks and I've also seen diagrams that say that all I need to do is to go to the passenger kick panel.  Can someone set me straight on this?
Also, is the Toyota Highlander the same as a RX300?
Moderator - Posts: 12,488
Posted: January 28, 2003 at 10:51 PM / IP Logged
|              12V|white & blu/yel     |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|black               |+  |ignition harness            |
|  SECOND IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|pink                |+  |ignition harness            |
|       POWER LOCK|see direct fax      |   |                            |
|     POWER UNLOCK|document #1070      |   |                            |
|       LOCK MOTOR|BLACK/ white         |   |17 pin plug, pin 1 @ BECU *1|
|     UNLOCK MOTOR|blue/red            |   |17 pin plug, pin 2 @ BECU *1|
|    DISARM DEFEAT|blue/black          |   |17 pin plug, pin 6 @ BECU *1|
| PARKING LIGHTS +|green               |   |driver kick panel           |
| PARKING LIGHTS -|GREEN/ red           |   |headlight switch            |
|       HEADLIGHTS|RED / blue            |-  |headlight switch            |
|     DOOR TRIGGER|GREEN/ YELLOW *2     |-  |ign. key cyl. illumination  |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|WHITE/ red           |-  |driver kick panel           |
|         HOOD PIN|GREEN/ black         |-  |top plug, pass side junc box|
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|red to blue *3      |-  |steering column             |
|       TACHOMETER|WHITE/ green         |   |28 pin plug, pin 27 @ ECM *4|
|      SPEED SENSE|wht/red or pur/wht  |   |28 pin plug, pin 22 @ ECM *4|
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|WHITE/ red           |-  |steering column             |
|           WIPERS|lt. green(L), red(H)|+  |steering column             |
|  LF WINDOW UP/DN|red - grn/red       |A  |LF window switch            |
|  RF WINDOW UP/DN|red - green         |A  |RF window switch            |
|  LR WINDOW UP/DN|red - green         |A  |LR window switch            |
|  RR WINDOW UP/DN|red - green         |A  |RR window switch            |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|blue / YELLOW         |+  |radio                       |
|     RADIO GROUND|brown               |-  |radio                       |
|     RADIO SWITCH|gray                |+  |radio                       |
| RADIO ILLUMINATE|green               |+  |radio                       |
|    POWER ANTENNA|BLACK/ red           |+  |radio                       |
|       LF SPEAKER|pink - purple       |   |radio or amplifier *5       |
|       RF SPEAKER|lt. green - blue    |   |radio or amplifier *5       |
|       LR SPEAKER|black - yellow      |   |radio or amplifier *5       |
|       RR SPEAKER|red - white         |   |radio or amplifier *5       |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.    *1 The BECU (Body ECU) is behind the glove box, it is the module to the right.  *2 To avoid the dome light delay, go to the Body ECU behind the glove box to get the individual door trigger wires. In the 19 pin plug, the driver door is RED / blue in pin 11 and the rear hatch is WHITE/ red in pin 6. In the 17 pin plug, the front passenger door is RED / blue in pin 16 and the 2 rear door is red in pin 15. Use all wires and diode isolate each.  *3 This is the key sense wire for the ignition switch. The wire changes colors after a junction plug. It is red on the ignition switch side and blue on the other side. Using the status output wire from the remote start to ground this wire will disarm the alarm without unlocking the doors.  *4 The ECM (Engine Control Module) is behind the glove box, it is the module to the left.  *5 The amplifier is under the rear load floor.
Mr_Fusion
Copper - Posts: 113
Posted: January 29, 2003 at 1:06 PM / IP Logged
Would you happen to know what the polarity is for the "Lock & Unlock Motor"?
How can I get the fax back document #1070?
Did you get this information from the CD that you advertise on your website?
Posted: January 29, 2003 at 1:10 PM / IP Logged
The motor polarity is (+) trigger. They should rest at nothing. Test the wires prior to hook up for verification of this though. I just emailed you a copy of the document needed.
camino
Copper - Posts: 54
Posted: January 30, 2003 at 8:04 PM / IP Logged
for the power locks you have tu go to the passenger kick,theres a special diagram for the locks,if i'm correct is 3 wires,i tjink jeff  can send you this diagram.is very simple.
el camino
Posted: January 30, 2003 at 8:50 PM / IP Logged
Yeah, I sent him the information already. The system is kinda funky but it makes sense after you get the diagram.
Chris Luongo
Platinum - Posts: 3,746
Posted: February 01, 2003 at 12:59 AM / IP Logged
Locks aren't too hard on these.  Go to the passenger kick.....
Find these three wires:
Lock---pink---tests by pushing the "lock" button on the door panel.
Unlock---light green----tests by inserting the key into the passenger door, and turning it to the unlock position.
Unlock Detection, a.k.a "child safety"----gray----shows a ground while the door is unlocked; goes dead when door is locked.
To lock the doors, you can just give a plain negative trigger to the pink wire.
To unlock the doors, split your alarm's unlock wire with two diodes.....send one to the gray, one to the light green.
Note:  The pink lock wire will NOT arm the factory alarm (if you have one).  If you need to arm the factory alarm, you must use the special relay setup that is usually mentioned for these cars.
Note:  If you want two-step unlocking, the only way to get it is to go into the driver's door.
camino
Copper - Posts: 54
Posted: February 01, 2003 at 7:27 PM / IP Logged
you got it
el camino
Mr_Fusion
Copper - Posts: 113
Posted: February 02, 2003 at 10:37 PM / IP Logged
thanks for all the info!!
