2000 nissan maxima alarm/remote start
craze
Posted: January 20, 2007 at 1:06 AM / IP Logged
I guys, i got a problem with a 556 dei bypass on 2000 nissan maxima with a prestige alarm/starter  the car turn over but it not starting i fallow the info ond  also the  the tranponder ring around the ignition ring all it do is turn over on over and not tarting can some  one help me please                                       thanks craze.
profuse007
Gold - Posts: 2,015
Posted: January 20, 2007 at 8:11 AM / IP Logged
It's car starts but doesnt turn over, not the other way around.
check the 556u bypass ring to see if its around the key cylinder/tumbler. the ring must be tight around the cylinder.
was this a self-installed or pro?
Houston,TX
KarTuneMan
Platinum - Posts: 7,056
Posted: January 20, 2007 at 9:26 AM / IP Logged
Both starter wires being used.......would this affect it not starting, but allowing it to crank? I don't know?
craze
Posted: January 20, 2007 at 10:04 AM / IP Logged
it's a self install and yes the cold start wire is huck up
Moderator - Posts: 12,488
Posted: January 20, 2007 at 5:54 PM / IP Logged
Check to make sure that it's not your wiring by placing one of the keys into the ignition column and try to remote start the vehicle. If it starts, then you have a bypass problem..... if it fails then you have a wiring issue.
craze
Posted: January 20, 2007 at 8:45 PM / IP Logged
thanks alot man
Saturday, September 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
