kia sportage and gsm alarm system
deetreuk
Posted: February 06, 2007 at 8:18 AM / IP Logged
hi guys'
can anyone tell me how to find
1 the door trigger + positive,
2 the door trigger -  negative
3 the engine trigger negative
I am attempting to connect a gsm alarm to my kia sportage and this is the only wiring connections i am having trouble identifying mail back at deetreuk@yahoo.co.uk if needed
many thanks.
Andy
Twelvoltz
Platinum - Posts: 2,384
Posted: February 06, 2007 at 8:53 AM / IP Logged
DEI lists:
Door Trigger      YELLOW /GREEN       -       drivers kick panel
You would not use the + trigger input on your system.
What is the "engine negative trigger"? If this is your hood pin, DEI lists:
Hood Pin      blue/white       -       hood pin switch
deetreuk
Posted: February 06, 2007 at 3:52 PM / IP Logged
hi guys..............again
can anyone tell me where to locate the coil on a 1996 kia sportage as i have been told there isnt one as this vehicle is injected???  I have a GSM car alarm systen to fit and one blue cable raps around the ht lead from the coil but where is the coil. kia sportage and gsm alarm system -- posted image.
if anyone fancies a foreigner or can help me fit this darn alarm it would be most apprieciated.kia sportage and gsm alarm system -- posted image.
I have the wiring diagram if anyone wants to view it but i will have to e-mail this to you personally as i dont know how to or if you can put it on this forum.
many thanks
Andy
Hymer
Silver - Posts: 695
Posted: February 06, 2007 at 3:57 PM / IP Logged
Its in the yellow/white diagnostic connector rear of the engin compartment, driver side. Tach wire should be WHITE/ blue
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
Thursday, October 17, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
