keyless entry, mitsubishi colt '93
andrekr
Posted: July 27, 2007 at 3:34 PM / IP Logged
Hello
I'm trying to install a keyless entry kit a bought on ebay. This is a kit with 2 acuators, a relay and transmitters etc.
I have already mounted the acuators in the doors, but I can't figure out how to do the wiring.
This is the install manual: http://www.blackwidowsecurity.com/installPDF/BW852%20Install.pdf
As I could understand, I have to connect a 12 volt source and ground to the relay box itself. And I need to hook up two wires from the relay to 12 volts (for the acuators). I followed the "adding acuator" diagram in the install manual.
Can I connect the 3 wires to the constant 12 volt wire at the ignition harness, at the same spot on that wire? Or must I connect them directly to the battery?
The acuators have to wires, one green, one blue. Where do I connect these on the relay? Should I connect the two green wires to the GREEN/ black wire on the relay and the same with the blue wires?
And what should I do with the Ignition input wire and the Parking light output wire on the relay?
I hope somebody out there can help me, I really want this thing to work :)
KarTuneMan
Platinum - Posts: 7,056
Posted: July 27, 2007 at 7:54 PM / IP Logged
keyless entry, mitsubishi colt '93 -- posted image.
Read in the manual about the pin#'s Then this picture will make sense. You unit has built in relays.
Monday, September 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
