Remote Start Hood Pin Neccessary?
Forum Name: Car Security and Convenience - Hot Topics
Forum Discription: Stickied topics from our Car Security and Convenience forum. Car Security and Convenience FAQs. Read First!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129204
Printed Date: May 20, 2024 at 2:22 PM
Topic: Remote Start Hood Pin Neccessary?
Posted By: bren5666
Subject: Remote Start Hood Pin Neccessary?
Date Posted: November 12, 2011 at 9:57 PM
Went and talked to the shop that is going to install my alarm next week.After going over a couple questions, one of the things he brought up is that they don't normally install a hood pin for the remote start due to the frequency of problems they have with them. I understand where he's coming from, but I'd like some other opinions on if it's needed.
Posted By: i am an idiot
Date Posted: November 12, 2011 at 10:15 PM
Very.
The purpose of the hood pin is to keep the vehicle from starting if someone is working on the engine. Would hate for you to have your hands in the fan or belt, and have someone wonder what this button does.
Posted By: aaronrs4
Date Posted: November 12, 2011 at 11:35 PM
Request that they install a tilt switch under the hood instead of a pin switch. That will eliminate any issues with the pin switch breaking or corroding... in my 12yrs of installing I've never had to replace a tilt switch unless the customer somehow managed to damage it...
------------- Install it like everyone will see EVERY part of it.
Posted By: howie ll
Date Posted: November 13, 2011 at 1:26 AM
And in the last 20 I've never had to replace a hood pin switch. If they are having problems and give you that answer they are doing things wrong and don't use them.
I live in a miserable damp climate and like everything else there's an art to their installation.
Mount as high as possible, seal the joint between switch and wire with adhesive heat shrink and spray over with a moisture retarder.
Posted By: KPierson
Date Posted: November 13, 2011 at 7:26 AM
They probably don't hook up tach wires either, or dome light supervision, or any other "non essential" item that doesn't make them extra money but takes more time.
Skipping the hood pin is inexcusable for a professional shop and any shop that tells you that they don't use them would instantly lose my business.
------------- Kevin Pierson
Posted By: smokeman1
Date Posted: November 13, 2011 at 9:00 AM
I'm a DIY guy and I would insist that they install a hood pin. Perferably a tilt switch as aaronrs4 recommeneds. I have replaced the standard pin as it would corrode in this climate and not function properly. I wouldn't think of installing without a hood pin. Usually the first thing I look for is how to get from the inside of the car to the engine compartment.
------------- When all else fails, Read the Instructions
Posted By: kreg357
Date Posted: November 13, 2011 at 11:05 AM
The Hood Pin is a very important safety feature as most users never take the time to use Valet Mode ( and I explain & teach them this feature ).
While a tilt switch does have some "hilly terrain" issues, I prefer them to the pin switches.
------------- Soldering is fun!
Posted By: bren5666
Date Posted: November 13, 2011 at 4:48 PM
Thanks for the advise guys. I actually thought of using a tilt switch, but where I normally park at it would likely cause an issue. They did say they would install it if requested, so I'm going to have them do it.I forgot to ask them about a remote start override toggle switch and I didn't even think of the domelight supervision; I'm going to have to make sure they do that also. Most of the shops around my area are only around a couple years then disappear. That's why I decided to take it to this shop. They've been around for about 15 years and have good reviews. Letting someone work on my new vehicle makes me a bit paranoid!
