I Want to Diode the 125volt AC Output of My Tiny Portable Generator
Forum Name: Miscellaneous - Off Topic
Forum Discription: Topics that just don't fit anywhere else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=144733
Printed Date: May 20, 2024 at 9:36 AM
Topic: I Want to Diode the 125volt AC Output of My Tiny Portable Generator
Posted By: canada chris
Subject: I Want to Diode the 125volt AC Output of My Tiny Portable Generator
Date Posted: September 17, 2018 at 8:02 PM
hi. i have a 60volt e-scooter and it charges my 5, 20amp/hour AGM batteries up to 72.5volts DC with 2.5amps[200watts] constant current, then floats at about 68volts when full.. i want to know from an electrical engineer what volts DC i will get if i get large diodes and clip half the sine wave of my 125volt 800watt pure sine wave POWERIT MODEL gn-1000 2 stroke oil generator. [not that it matters but my Motorino Brand e-scooter has a 500watt "AC" motor in the rear wheel]
i want about/at least 66volts and clipping half the sine wave i guess i am losing about half the watts too,... but i just want to extend my range and have an emerg charge to get home with/in my trailer. it might even charge/power as i ride LOL
be well all my new good friends and God Bless from canada chris
------------- A LITTLE CRITICAL THINKING AHEAD OF TIME CAN SAVE YOU A LOT OF LAYERS OF SKIN AND PINTS OF BLOOD
