2012 Nissan Sentra, Door Open Indicator Stays On
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=145867
Printed Date: May 12, 2024 at 2:33 PM
Topic: 2012 Nissan Sentra, Door Open Indicator Stays On
Posted By: njsdesipunk
Subject: 2012 Nissan Sentra, Door Open Indicator Stays On
Date Posted: December 18, 2019 at 9:14 AM
while installing remote start in my 12 sentra, I accidently broke dooe unlock wire on BCM connector.I connected a cable using another cable but Now my door open sign on cluster stays on.
Can someone help me repair this issue?
Posted By: geepherder
Date Posted: December 21, 2019 at 5:33 AM
The first thing I would do is disconnect the door jamb switches one at a time to see if the door open indicator light goes out.
This will tell you if there's an issue with one of the switches that may coincidentally be causing the issue.
Posted By: eguru
Date Posted: December 21, 2019 at 7:47 AM
I don't know how the Sentra door switches work but on many vehicles the door switch is closed when the door is closed.
Disconnecting the individual door jamb switches won't help identify the cause if that is how Sentra implements the door open check.
If the BCM connector was removed to repair the broken wire, perhaps it is not latched properly or an individual contact has been pushed back into the mounting wafer.
Date Posted: December 21, 2019 at 9:05 PM
As eguru points out, it is important to know what type switches your car uses. Your door switches should show a ground when the door is open.
https://www.bbbind.com/tsb-wiring-diagrams-database-results/?type=WD&years=2012&make=65&makeDesc=Nissan&model=832&modelDesc=Sentra&system=17&systemDesc=Warning%20Systems&subsystem=197&subsystemDesc=Warning%20Lamps&docid=8197119
Be sure to also check the trunk switch (it may be built into the latch assembly). If your testing doesn't reveal a shorted switch, you can test the wires while the switches are disconnected. The door switches only have one wire. They should not test as ground while disconnected. The trunk switch has two wires, one black and one white/green. White green should not be grounded while disconnected.
